Does ArcGIS for Server 10.1 support DGN data layers ?
2508
11-27-2012 08:01 PM
VishApte
I have some vector datasets in Microstation DGN v7 file format. I added these DGN files in ArcMap as layers and they are displayed correctly with symbology based thematic etc. However, when I try to publish this map as ArcGIS for Server Map Service, I get "Layer type is not supported" critical error for all map layers that are DGN files. Does ArcGIS for Server support DGN files? If not, is there any documentation on which data types are supported by ArcGIS for Server. I thought everything that ArcMap supports can be published to ArcGIS Server.
Vish
nicogis
here you can see supported functionality in map services:
http://resources.arcgis.com/en/help/main/10.1/0154/01540000044r000000.htm
