Distributed Collaboration not Syncing Updates
6857
10
01-10-2023 05:31 PM
SBerg_VHB
Hi, any input at all would be appreciated but looking for suggestions on how to best approach a distributed collaboration (Enterprise + AGOL) which is failing to sync updates (on schedule, using the UI, or by API Sync).  The portal logs indicate sync successes without errors (shows result counts for exporting packages although suspiciously shows 0 results for import packages) but the edits are not making it in either direction (bi-directional sync).  There do not appear to be related errors in the portal logs.
The initial sync from Enterprise to AGOL worked without issue and the endpoints of course have sync enabled.
Any thoughts on how to best diagnose would be appreciated.
Thank you,
Sam
Caitlin_Todd_LCOR
Is anything still having this issue between two ArcGIS Enterprise Portals, both at 11.4, when trying to sync bi-directional edits?
