Deciphering Tracking & Traceability code in SDE
996
08-02-2022 12:25 PM
JasonCyphers
I've used the decoders in the Attribute Rules folder of the Digital As-Builting configuration.
The arcade expressions work great to display the deciphered ASTM F2897 barcode in the Field Map attribute pop-up; however, because we utilize SDE for modeling of our gas utility infrastructure (for connectivity and network tracing), I need a way to decipher the barcode in SDE.
What's the best way to do this?
TomDeWitte
Hi Jason,
The same arcade scripts you have used in the Field Maps pop-up can be used as attribute rules in Enterprise 10.9.0 or higher, they can also be used in Field Maps form expressions which is available in ArcGIS Online and Enterprise version 11. The attribute rule method will decode and auto-populate when the Field Maps user either submits the edit or syncs the edit depending on whether they are connected or disconnected.  The Form Expression method will immediately decode and auto-populate the barcode as soon as the barcode is scanned. This will work in both a connected and disconnected configuration with Field Maps.
You will find more information on how to configure Field Maps for Tracking and Traceability in the Gas Industry portion of the Esri Community.
Tom DeWitte
Tech Lead for Natural Gas and District Energy
email: [email protected]
