Debug/Troubleshoot - UN - Branch version slowness
842
09-30-2022 12:23 PM
AntheaTung
Hi there,
The GIS environment we are on:  ArcGIS Enterprise 10.8.1 (with the performance patch installed), UN version 4, Azure SQL Server v12 and ArcGIS Pro 2.9.3.  The entire stack is hosted on Azure cloud services.
Currently working with UN Feature Services on Gas data model.
When I create a new branch version on the UN feature service, it takes between 42 seconds to 1 minute 31.4s.
There seems to be a pause of approximately 30 seconds in the create version (through the Version Management > New version tool)  that ArcGIS Pro is waiting for something and then the after the 30 seconds, it will change to the new version and draws the map.
I have used Fiddler and there are lots of REST response activities (e.g. validate token for the feature layers).
Wonder is there a way I can troubleshoot  what could be causing the differential timings on one system?
Would it help to turn sdeintercept on the ArcGIS Pro client side?
I used ArcMON in ArcGIS Pro (in debug mode) and does not have the kind of information I am looking for.
Also is there a way to see how much long a feature service's layers are to load in ArcGIS Pro?
Thank you in advance.
