Content Mobile - Web adaptor - Name instance
1187
12-17-2012 02:33 AM
nicogis
I have configurated Web Adaptor IIS for ags 10.1 sp1. The web adaptor have name != arcgis so when I connect to mobile content using
http://myserver/myname/mobile/content, I see the page but the references are to 'arcgis' and not 'myname'. While url for admin, services is all ok.
Have a problem the combination: webadaptor & content mobile & Name of web adaptor != arcgis ? Seems don't get name of web adaptor so all url in page aren't right.
If I connect with http://myserver:6080/arcgis/mobile/content I haven't problems.
nicogis
Thank you for replay. For now the workaround isn't practicable.
For now I install multiple arcgis web adaptor iis on same machine so I add the 'arcgis' name for web adaptor http://resources.arcgis.com/en/help/install-guides/arcgis-server-web-adaptor-iis/10.1/01nz/01nz00000...
KellyGerrow
Esri Alum
Good Morning,
The error that you are describing is a known issue.
The following bug has been logged:
http://support.esri.com/en/bugs/nimbus/TklNMDg1NDUx
The current workaround is to use the default ArcGIS instance name.
nicogis
