Confirming active extensions
1785
12-17-2013 12:10 PM
gabrielvazquez
Is there a way to verify what ArcGIS Server 10.1 extensions you have enabled(e.g., Network Analyst, Spatial Analyst, etc.) on a GIS Server, perhaps similar to desktop? We are using ArcGIS Server 10.1.
We are having some issues with publishing services requiring Network Server. Every time I attempt to publish a routing service to our local GIS Server I receive an error code: 00147 "The Network Analyst extension is not licensed on the ArcGIS Server". I imagine this error is a result of extension licensing issues, however I've authorized our GIS Server with Network Analyst and we are using Server Advanced.
Regardless, I am trying to see if anyone is aware of way for you to check what extensions are authorized on an ArcGIS Server. I want to see if the ecp file we are using is actually authorizing specific extensions.
gabrielvazquez
crafty,
Thanks for the response. The ecp file is whats confusing me, because as you've described I've viewed the ecp file in notepad and it has a network analyst. Yet when I try to publish anything using requiring the network server it doesn't work.  I am at a loss at this point as to why its not working.
WilliamCraft
If you are certain that the 'yes' is the answer to the following two questions below...
[INDENT]Is there only one ArcGIS Server in your site?[/INDENT]
[INDENT]Are you confident that the ECP number you're using for the Network Analyst extension is valid and is for the correct version (i.e., 10.0, 10.1, 10.2)?[/INDENT]
... then I would recommend that you contact Esri Tech Support to investigate the issue further.
