Configuring 2 Webadaptor to Portal for Arcgis
2665
03-09-2020 07:50 AM
SoratoSouza_e_Silva
It´s possible to configure two webadaptor´s for a single portal? One in a machine to public access and other on another machine to access the administrator?
Thank´s
Tags (1)
RachelSears
Hi Sorato,
Yes, you can configure two Web Adaptors for one Portal.
Keep in mind you will need to run the Web Adaptor installer twice to install two separate Web Adaptors; do not "double-configure" one Web Adaptor installation.
Hope this helps!
- Rachel
RachelSears
Hi Sorato,
Hope this helps!
- Rachel
SoratoSouza_e_Silva
hmmm very good.
 Can I do this for Arcgis for Server too?
Thank´s
RachelSears
ThomasJones1
Hello Sorato Marques‌,
There are circumstances where you would configure multiple portal Web Adaptors. Typically this would be for high-availability portal deployments. To configure multiple Web Adaptors with Portal for ArcGIS, a single endpoint must be used to access the portal. In additional it  is necessary to configure a 'WebContextURL'.
Configure multiple ArcGIS Web Adaptors—ArcGIS Web Adaptor (IIS) Installation Guide (10.8) | Document...
Portal only supports a single DNS or one 'URL' to access the portal. For example it's not possible to have two portal Web Adaptors one in the DMZ and another internally using two different URL's.
https://community.esri.com/thread/215991-how-to-add-an-additional-web-adaptor-for-external-maps
Hope this helps,
Thomas.
