Concatinating fields on the fly into a virtual field for feature services
1801
11-18-2021 02:11 PM
LyonMNGIS
I have a 3rd party that would like me to add an attribute to a feature service layer.  This field can be calculated from other fields.  I don't want to add a field on the main dataset as this will only be used for a specific application.  Is there a way to add a virtual field within a hosted layer view?
Thanks!
JohannesLindner
AFAIK, not directly.
You have a few options:
  • use Arcade to show the virtual value in the popup
  • create the field, but calculate it automatically using an attribute rule
  • instead of publishing a feature class, publish a database view that contains the virtual field, calculated with SQL
Have a great day!
Johannes
Scott_Tansley
MVP Regular Contributor
Assuming your software versions support it, then take a look at Arcade and the text functions there:
https://developers.arcgis.com/arcade/function-reference/text_functions/
Regards,
Scott
Scott Tansley
https://www.linkedin.com/in/scotttansley/
JohannesLindner
Have a great day!
Johannes
