Collaboration time out
13110
33
08-12-2024 11:14 AM
TL2
I have multiple workspaces that are timing out.  I have created new workspaces in my collaboration and they too time out once adding a FC.
The request to import replication package on the portal with id 'b33b17fa-348e-4540-b3fb-18af8928fedc' timed out. The job '05a73d26b7e04ccfad215cf7079fd6f4' on portal 'https://mmmm.maps.arcgis.com' timed out.
Anyone else experiencing this?
LisaDong
Esri Alum
@valenj88 @DavidColey @KatherineStaley @MichaelJenkins
If anyone is encountering this issue, please log a case with Technical Support.
DavidColey
MVP Frequent Contributor
Ok @LisaDong I filed a support case as an ArcGIS Online issue.  Case number is 03698316.  I added the BUG-000169932 to the support request, and am asking support to review what has been posted here thus far.
@valenj88 @MichaelJenkins @KatherineStaley @TL2
LisaDong
Esri Alum
@DavidColey That's perfect! Thank you David~
MichaelJenkins
I have logged a case as well
GISP
Rberning
We've been running into the same issue as well. Logged a case with Technical Support yesterday (requesting our server logs - and for some reason, can't download the .crpk file) - still waiting for a follow up. I see a BUG number listed below but I can't find it on the technical support website. Is there a way that the link could get provided to see what information is known so far? Thanks!
DavidColey
Tech support contacted me last night with the following:
This is ***** from Esri Support Services, writing in reference to case #03698316. I have taken ownership of the case and will work with you to reach a resolution.
Based on the notification, I understand that you are reaching out about BUG-000169932: Collaboration Timeouts in ArcGIS Online. Please be informed that the bug you mentioned is related to the current service disruption, which is affecting multiple organizations.
Our operations team is actively working to resolve the issue, and I will keep you updated with any new information regarding this incident. Additionally, I have attached the bug to your case, and you can view the status of the defect through the following link
  • My Esri > My Organization > Support > Search for BUG-000169932
So - Current Service Disruption.  That makes sense to me, as there have been other flaky things with Content - like items still showing in one folder or one group after moving or deleting until I physically refresh the browser.
Alex_at_Exprodat
We had failures from ArcGIS Online collaborations to both test and prod Enterprise 11.1 environments. As with others, the step "Export and download peer replication package" was timing out after 2 hours.
This started on Friday, 9 August and failures continued through yesterday, Tuesday, 13 August. As of today, Wednesday, 14 August, all collaborations appear to be syncing normally again with no failures.
We did not take any action on collaborations such as removing/re-adding workspaces, deleting collaborated items, unsharing/resharing items, etc. We just left it alone and everything is working again.
Hope everyone else finds their collaborations working normally again today!
KatherineStaley
Glad your sync is working! Unfortunately, our sync just failed again.
LisaDong
Esri Alum
Hi Katherine, please test again when you have an opportunity.
KatherineStaley
Unfortunately, mine failed again. Should I open a ticket?
