Can you install ArcGIS for Server Advanced Enterprise on SQL Server Express
9792
42
09-04-2014 04:31 PM
JaromHlebasko
I am fairly new to ArcGIS for Server and I am trying to read up on documentation about different database management systems and I cannot seem to find an answer on whether or not I can install ArcGIS for Server Advanced Enterprise on SQL Server Express? I'm trying to set up an Enterprise Geodatabase with the trial version of Server Advanced Enterprise. Any help would be much appreciated.
AsrujitSengupta
Yes, SQL Server Native Client is indeed required on the machine. However, the error that you are getting may not be caused because of that.
Is the user mapped to any SQL Server database?
JaromHlebasko
I did not select any database from the pulldown on the bottom of the window. All I am seeing is a report server by the name of "ReportServer$SQLEXPRESS" or "ReportServer$SQLEXPRESSTempDB" which I do not think is correct. Will I have other options if I install the client?
AsrujitSengupta
Those two options will show up...that is not an issue.
You are able to see those, that indicates that SQL Server Native Client should already be installed (check this).
Once you create more databases\geodatabase in that SQL Server instance, you will see more options in that dropdown.
JaromHlebasko
Am I supposed to choose one of these options to establish my Enterprise Geodatabase (SDE)? If I'm reading the help topics correctly, establishing the database server is for a Workgroup license right? I can establish a connection to the server but I tried creating a Geodatabase under the server node and it brings up a dialog box stating that it is not licensed. This is quite confusing!
AsrujitSengupta
What kind of SDE geodatabase are you planning to create? Personal, Workgroup or Enterprise?
JaromHlebasko
Since I have a Server Enterprise Advanced Licensed, I would assume that I would want an Enterprise Geodatabase; however, this is very new to me. I would like to author my map services with an Enterprise Geodatabase so i can author my map services for out in the field editing.
AsrujitSengupta
Have a look at the links mentioned in my very first post in this thread.
Use the "Create Enterprise geodatabase" tool to create the sde enterprise geodatabase tool.
JaromHlebasko
Thanks a million!
JaromHlebasko
I was able to successfully install an Enterprise Geodatabase yesterday before leaving work; however,I turned my computer on this morning and for some reason, I cannot connect with my server via localhost:6080/acgis/manager. Would installing SQL Server Express have something to do with this? I had a lot of connections through ArcCatalog which are not working as well.
AsrujitSengupta
No, I don't think that has anything to do with installing SQL Server Express.
I would suggest creating a new thread for the ArcGIS Server issue, as this thread mainly concerns the installation and creation of the enterprise gdb.
