Can we publishing only one data table on ArcGIS Server?
2822
05-13-2014 12:57 AM
by Anonymous User
Not applicable
Original User: gsenyurdusev
When I publish a data table;
[ATTACH=CONFIG]33772[/ATTACH][ATTACH=CONFIG]33773[/ATTACH]
"Service" buton is passive and can not publishing a table.
Can ArcGIS Server only share "Feature Class"?
TanuHoque
as of today, you must have at least one layer in your map document in addition to your table in order to publish that map document as a map service.
PhilLarkin1
Is this still the case? At 10.3.1, it seems I must add a feature class to a service of stand alone tables.
by Anonymous User
Not applicable
Original User: GISDev01
One workaround for this is to just have a feature class in your map document that has no data in it, along with the table that you are trying to serve out.
