Can't start ARCSde Service(esri_sde) 10.1
4403
04-09-2015 01:17 PM
VitorFortunato
I have installed ArcSDE 10.1 on Windows Server 2008. When I try to start it I get the message : The ArcSde Service(esri_sde)service on Local Computer started and them stopped. Some services stop automatically if they have no work to do.
sde_esri_sde.log
ArcSDE 10.1  for Oracle10g Build 768 Thu Aug 23 15:57:13  2012
DB_open_instance()::db_connect (OCI8) error: 12560
init_DB DB_instance_open_as_dba: -51
DBMS error code: 12560
ORA-12560: TNS:protocol adapter error
VinceAngelo
Esri Esteemed Contributor
There's probably several hundred posts on this topic, and there might be a hundred different solutions.  You'll need to provide a lot more information about the exact releases of all software, the exact configuration details, the exact commands used to create the service, and detailed information on how the geodatabase was configured before we can give more than RTFM-like assistance.
- V
RebeccaStrauch__GISP
If you haven't already looked at this ArcGIS Help 10.1 troubleshooting page, that might give you a clue.  I remember seeing this error on our install in the past (SQL, not Oracle).  If you do a browser set, as Vince mentioned, there are many posts and many causes.  If the troubleshooting doc or other posts don't help, I would recommend calling this in to support.
