Can't Register UNC Directory
3127
07-19-2012 06:18 AM
BrianLeroux
I am trying to register a UNC directory and get an error "Invalid folder location. Unable to access this location." The Windows Domain account the server is using has Share and NTFS read permissions to this directory and has been tested outside of ArcGIS and works fine. Any ideas? This seems to me that it is another issue with how ArcGIS handles authentication when using Active Directory. Any ideas?
EricJackson1
I am having a similar problem.  The arcgis soc account has the needed permissions but when I try to register a UNC folder i usually receive a "Invalid folder location. Unable to access this location." message.
Oddly enough SOMETIMES it works and will validate.  Then a short while later it fails to validate!  Very strange.
Interestingly I can also use the exact same folders as used for the server directories, and those fail when used as Data Store directories.  They work perfectly fine when configured as server directories!  The server all runs under the same ArcSOC account so this makes no sense.
Did you find a resolution?
Eric
