Can permissions be set on map services?
1901
10-20-2014 10:57 AM
GeoffreyWest
My goal is to create an application where services can only be accessed by those with certain permissions, much akin to ArcGIS Online web-maps, however I would like it so that when a user pings the URL where the map services is being consumed, that a log-in box appears that references ArcGIS Server?
ToddJackson2
Hi Geoffrey,
In ArcGIS for Server you can secure services such that they are authorised to -
  • LDAP/Windows Domain Groups
  • Built-in Roles
The services can be configured to enable/disable the capabilities and operations they expose.
Users can be authenticated using token authentication, or integrated Windows authentication, if a Web Adaptor is being used in the site configuration.
If using token authentication APIs like the javascript API have an IdentityManager class that wlll provide a login dialog for users to provide their credentials, which in turn acquires a token from ArcGIS for Server, which is then supplied when accessing secured services.
See the following links for more information -
http://resources.arcgis.com/en/help/main/10.2/index.html#/Securing_your_ArcGIS_Server_site/015400000...
https://developers.arcgis.com/javascript/jsapi/identitymanager.html
Cheers,
Todd.
