Can I connect and use SQL Server 2014 with ArcGIS Enterprise 10.9.1 Setup
938
03-29-2023 03:34 AM
sahook1
Hi All,
 I have federated ArcGIS Enterprise 10.6 on-prem which is connected with SQL Server 2014.
Currently I have challenges with SQL Server upgrade, Can I upgrade ArcGIS Enterprise independently and connect SQL Server 2014?
Any known issue or connectivity issue is there?
Any help here will be appreciated.
Kruttibas
ChrisUnderwood
The newest version of ArcGIS Enterprise that is supported with SQL Server 2014 is ArcGIS Enterprise 10.8.x. So you cannot upgrade to a version higher than that and still use SQL Server 2014. (note specific SQL Server 2014 SP3 requirement)
https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-sqlserver.htm
