CachingTools service
1273
06-24-2014 04:25 AM
BrentHoskisson
Stupid question:
In Pooling there is a note that says "If you plan to generate cache and want to improve the speed of cache generation, go to the System folder's Caching Tools service and increase that service's instances."
What does it mean "System folder"?  Exactly where is this so-called CachingTools service?
DavidColey
MVP Frequent Contributor
Hi brenth-
It means in your server conneciton in Catalog, go to the system folder, open it, right-click the CachingTools service and open the Service Editor window, go to Pooling, and increase the max number of instances to n+1 the number of cores you have available (eg 12 cores, set to 13 instances)
David
DavidColey
Hi brenth-
David
