Automatic Field Updates once data insert or update
1361
01-08-2024 01:01 PM
vijaybadugu
Hi, We have recently published the data with point and polygon together as webmap for QuickCapture. I need to update the integer field value as a random number generator and it should be Unique . I created Rel_GlobalID field to maintain relationship between point within the polygon.  in polygon feature class, If point is within the polygon, I am updating the point feature GlobalID in the polygon feature of Rel_GlobalID, otherwise updating null value to it.  I am doing with SQL triggers. to maintain consistency, Can we do same thing in arcade or some other functionality to achieve this.
MarceloMarques
Attribute Rules are stored with the Geodatabase. The Attribute Rules are triggered when the edits are performed via a Feature Service or via ArcGIS Pro editing the featureclass directly. That is the power of Attribute Rules.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
Introduction to attribute rules—ArcGIS Pro | Documentation
vijaybadugu
The same can be worked even after publishing the either feature service or map service ?
MarceloMarques
