ArcSever Tile Cache: Create Overzoom Effect
6755
11
04-20-2017 12:02 PM
DavidColey
MVP Frequent Contributor
Hi - I asked this in response regarding a method to prepare a tpk for offline use: How does esri create the 'overzoom' effect for the world topo map service?  Clearly the large scales say past 1:564 are drawing at the same resolution, but I can't figure out how to do that with my own caches.  I thought it would be as simple as copying my largest bundle's LOD into the even larger levels, but that doesn't work.
Does the cache have to be exploded?  Does it matter if the tile format is PNG vs JPEG?  Any suggestions?
David
DavidColey
Sorry, a bit more. Found this link:
Latest ArcGis jsapi library resamples images, this doesn't · Issue #240 · Esri/esri-leaflet · GitHub
Looks like Tilemap is a custom capability maybe in the form of and SOE that handled a resample of existing tiles when a zoom level encountered a missing tile.  Also looks like any work on it is stopping or has stopped becasue vector tiles will be superceding this method.
Looks like I'll stop chasing this one......
RebeccaStrauch__GISP
David, you may want to mark this thread as "assumed answered" to close the thread, since there isn't really an answer.
