ArcGIS server
4701
12-23-2014 08:17 PM
ManeshSharma
Hi all
I have published a Feature service from SQL server 2008 R2 on the Arcgis Server 10.3. Now if i open the feature Service in arcgis Flex Viiewer , it is opening fine. I have configured the Popups for the Attribute visulization and when i click on any feature. it show me the Attributes. What i want is basically is that i want to see the Atttributes in mine language. i.e gujarati. IS that possbile that i can see the Attributes in mine language..
Regards
DerekLaw
Esri Esteemed Contributor
Hi there,
FYI, the ArcGIS Viewer for Flex currently has built-in support for 23 languages,
Localization - ArcGIS Viewer for Flex
To add support for additional languages, you will have to localize both the application programming interface (API) and the Viewer. This will require some custom development work.
Further localization - ArcGIS Viewer for Flex
Hope this helps,
