ArcGIS Server Manager and Feature Service
743
10-12-2012 05:19 AM
KimSchubin
Good Morning,
This is a continuation of an issue I'm having with Feature Services. I've successfully created a feature service with no errors when I publish and I can open and view it in ArcGIS.com Map from Rest Service Directory. I can't seem to bring in the Feature Servce to the Server Manager. It only has it as a Map Service not a Feature Service. When I choose Feature Access capabliites and I go to configure the Editor Task in the web application manager, it gives me this error:
"This task requires an ArcGIS Server Local Service that is based on a map document (MXD). Please add an ArcGIS Server Local Service that is based on a map document (MXD) on the previous step before configuring the task."
Also, I can edited the web application in ArcGIS.com Map, but it doesn't seem to save the edits.
What is going on? What am I doing wrong? Help please!
Thank you!
nicogis
you cannot use feature service ( see feature service use ) with editor task adf (see web editing). However Editor task cannot use service 10.1
