ArcGIS Server Logs stop working
1086
02-25-2014 07:01 AM
RudolfKopriva1
We have been using ArcGIS Server Logs REST queries to parse logs from previous day. Queries works great for about 50 days in a row, but then is suddenly stops working and each query returns exactly the same result after exactly 10 minutes of execution. The result is: {"hasMore":false,"startTime":0,"endTime":0,"logMessages":[]}
If it's a sever issue, then I would expect REST error or timeout, but not an empty result. Server restart does not help and we can't even browse logs in the manager console (the loading query never ends). However we can see logs for last hour.
How can we restore log queries?
WilliamCraft
Are you able to view the logs from ArcGIS Manager as expected?
I've heard of very similar behavior before; the thread below discusses the details of that particular case.  It doesn't contain a specific fix, but it might send you in the right direction for troubleshooting further:
http://forums.arcgis.com/threads/98715-Problem-viewing-ArcServer-Log-Entries-via-the-Rest-Endpoint-A...
