ArcGIS Server log warnings and severe warnings?
7559
9
08-30-2022 04:38 PM
by Anonymous User
Not applicable
Hello all!
We are constantly getting warning logs and severe level warnings in our ArcGIS Server Manager View Log Messages page. How in the world do I figure out what these mean? Every time I get one I google search and I get nothing that helps. Do I have to call Esri Tech support for every one of these?
Any advice would be appreciated.
Just a handful of the many for a sample:
Error: The item was not found. on a MapServer
Error processing request java.lang.NullPointerException. on Rest.
Unable to perform query operation. on a MapServer.
Error: Operation without query criteria is not allowed. on a MapServer.
Unable to process request: Error handling schema request: java.lang.Exception: java.io.IOException: Server object extension 'validationserver' not found.
Thank you!
RamakrishnaBillakanti
It appears you have a SOE on the map service which is looking for additional details which map service map not have. Take a look at your SOE
ZachBodenner
MVP Regular Contributor
Regardless of the reason for this specific log result, I'm with you. I would also like an easier way to understand what all the log results mean. I do occasionally get results from google searching etc, but it feels like ESRI could put together a more user-friendly repository of the different kinds of log results.
Happy mapping,
- Zach
HéctorMeléndez
@Anonymous User Did you find a solution to your log warning 'object extension 'validationserver' not found' ? In my case the error appears for a branch versioned service. There is no SOE enabled on the server.
by Anonymous User
Not applicable
Hi there,
No, I never did find a solution. We don't use branch versioning either.
MatthewGeorge
@HéctorMeléndez
We also see this error in our logs and we don't use branch versioning for any of our data. Looking at the logs it seems to be a constant cycle of:
* Unable to process request. Error handling schema request: java.lang.Exception: java.io.IOException: Server object extension 'versionmanagementserver' not found.
* Instance of service 'System/DynamicMappingHost.MapServer' failed to process a request.
* Service instance activation failed in 'System/DynamicMappingHost.MapServer'. AutomationException: 0x80004005 - Unspecified error
AndreaB_
OP here - re-subscribing with my new community account.
ChrisDalla_Piazza
I wonder if there is a minimum ArcGIS Enterprise version to host a branch versioned feature service.  I noticed that the documentation on ArcGIS Pro cuts off at version 3.0: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/branch-version-scenarios.ht...
I believe ArcGIS Pro 3.0 corresponds to ArcGIS server 11.0.  We are on 10.9.1 and see the same error messages.
JasminePrater
I know this is an old comment, but for anyone researching the same issue, we are still having the issue using Enterprise 11.1 and Pro 3.3+.  It was listed as a bug here: https://support.esri.com/en-us/bug/arcgis-server-returns-the-following-error-message-in-th-bug-00013....  Here I am, years later, still trying to solve the problem.
AndreaB_
this post is helpful https://community.esri.com/t5/publishing-and-managing-services-questions/arcgis-server-severe-error-... and one commentor says one of the bugs is fixed at ArcGIS Pro 3.4. A few years from now our users will be on 3.4....lol.
