Arcgis Server is not creating cache. Tile generation is not in progress.
21217
10
05-30-2013 08:35 AM
ErdemEkinci
Hi everyone
I am beginner at arcgis 10.1 Server. So I am working on small sample data. I ve configured my mxd file. and wanted to publish at my localhost. I set my cache settings, my scale levels, Image Format(PNG32). then I clicked publish button. After a short progress it said completed. But I don't believe. because It couldnt be that much short. When I want to test at preview page, I saw I was correct. It was showing white blank page. no map.
I clicked "View Cache Status". It says %0.0 of the tiles are present. and the generation is not in progress.
I searched it on internet. I tried something. I restarted ArcCatalog. but no. Still 0.0%.
but after an hour, in some way that I dont know, I realized map comes to preview. that time I though it is ok. but when I zoom to low scales, map was blur. So only small part of map has been generated. I checked View Cache Status. Now It says 1.2%. but still says "Tile generation is not in progress". Now it is still not generating.
I Also made small tests at Arcgis Server 10.0 months ago, but I din't get this problem?
what is the solution of this? how can I force arccatalog to generate tile?
rawansaleh1
Hi Josue,
usually I resolve this by applying manage cache tiles or by cancel job then re complete job. See below
hope this works fine with you.
Best,
Rawan
