ArcGIS Server Installation Questions
1708
11-02-2022 04:27 AM
JD1016
This posting is somewhat of a follow-up to a previous post I submitted entitled "ArcGIS Server Pre-Install Questions" for which Scott Tansley and Brian Wilson did an admirable job attempting to shed light on documentation mysteries and meanings.
I believe the question I have this time should be fairly simple to answer, but let me set the stage first and repeat myself somewhat from my last post.
We are in the process of retiring a server that is currently running ArcGIS Server 10.4.1.  We do not employ Portal.  Our new server is up and running and we have been actively applying the pre-requisites for ArcGIS Server 10.9.1, Data Store, and Web Adaptor.  My question...
Can I install ArcGIS Server 10.9.1 on our new server without affecting or interrupting any of our current services running on the old server?  Logic would dictate that I can, however, I would feel more comfortable hearing from our community of experts for confirmation before proceeding.
Can I also install Data Store and Web Adaptor (which will go on a separate web server) and not cause any issues to our current running services on our old server?
Ideally, I would like to have everything installed on our new server, have our old server still running our services, re-publish all services through the new 10.9.1 version for ArcGIS Online, and be able to do a seamless swap between the two.  Perhaps too much to hope for?
Thank you in advance for reading my post.
Jeff
berniejconnors
Jeff,
        As long as the old and new servers are using different http addresses there should not be any conflicts.  My organization and many others simultaneously run a staging server and a production server for ArcGIS server.  There are no conflicts because the staging server and the production server have unique http addresses.
Bernie.
berniejconnors
Jeff,
        We have done similar upgrades several times and the cut-over from the old servers to the new servers has always been quite easy.  It is all done with the network.  Right now all of the ArcGIS Server traffic is being directed by your firewall / proxy server to https://old_server/arcgis/rest/services.  When you are ready for the cut-over you can reconfigure your firewall / proxy to send the traffic to https://new_server/arcgis/rest/services.
        I am not a networking expert so the above is short on details.  We have a great network team to support us.  You should reach out to your IT / Network admin to assist with the cut-over.
Good luck,
Bernie.
JD1016
Bernie,
Thank you so much for responding to my post.
So just to confirm...my theory is correct in that our new server is isolated from all traffic and any installations applied to it would NOT affect the current running services on our old server.  Is that right?
Jeff
berniejconnors
Jeff,
Bernie.
JD1016
Thank you, Bernie!
Jeff
