ArcGIS Server generate token - LDAP error 201 - Timeout
1410
02-13-2017 05:45 AM
MaximeDemers
From times to times, ArcGIS Server 10.3 failed to generate token because of an error 201 detailed as Error 201 - LDAP Response read Timeout, timeout used:-1ms.
In the logs, I see that the DC used for those failed request are not complete. Only the username was sent to the LDAP server instead of the username and password.
This error is happening randomly. Most of the times the generate token service returns the token correctly.
Any idea what could be the cause of this?
LittleTurtle
Hello Maxime, did you ever figured out what caused the problem? we are in 10.81 with the same problem.
I'm wonderying if it is an AGS problem or LDAP problem and if something can be done on the AGS part other than updating the version?
