ArcGIS Server cannot start services such as printing tools and orthomapping tools
2958
07-28-2022 11:53 AM
LukeSchwab
When trying to start some of the services on the ArcGIS services manager, I get the following error:
Utilties.PrintingTools.GPServer: com.esir.arcgis.discovery.servicelib.AGSException: java.lang.Exception: java.lang.Exception: The server was unable to access the URL 'https://machine.domainame.com:6443/arcgis/services'
I know the TLS connections have already been checked in IE to allow TLS 1.1, 1.2, and 1.3 for the local user and the domain user that the program was set up as. I also gave the same domain user permissions to all the folders in ArcGIS.
Some of the debug logs in the associated ArcGIS server manager says
ARCGIS_PORTAL_TOEKN Authentication, Unable to validate token com.esri.arcgis.discovery.admin.security.AGSSecurityExcpetion: Server machine 'https://machine.domainname.com:7443/arcgis/sharing/rest/community/self' returned an error 'Invalid token'
What am I missing?
MCameron
Hi @LukeSchwab
Based on the first error message, I would suggest working through the following Technical Article that may help resolve the issue: https://support.esri.com/en/Technical-Article/000021385 .
If this does not help to resolve, could I ask you to check if your server logs also show the following error:
Error: A connection with the server could not be established (WinINet Error while using HTTPS security, 12029), URL = https://<machine>.domain.com:6443/arcgis/services
If so, could you please change the Internet properties for the ArcGIS Server Account by completing the following:
  • Go to Internet Options > Advanced > Security
  • Un-check 'Check for publishers certificate revocation'
Let me know how that goes!
Martine
LeoDCG
any resolution? having a similar issue.
