arcgis server administration issue
14629
20
11-29-2012 09:05 AM
AnthonyCalderon
Hi All -
We are having an issue connecting to arcgis server 10.1 from arc catalog.  We are able to log into web manager interface but arc catalog returns: "Access to this resource is forbidden, regardless of authorization."  I had it working on one workstation right after the server was installed but now none of our workstations are able to connect through catalog.  We are running 10.1 SP1 on the server and clients.
Additional note, we are able to connect from catalog if we choose "use" but both publish and administer return the error above.  I have tried both internal auth and windows auth and both return the same error.  I have searched the interweb and have not found any one else reporting this issue.
Any help would be greatly appreciated.
AndrewBrown1
Update: I was able to allow administrative access for myself by adding my IP under "Allowed Administrative IPs:" under http://server:6080/arcgis/admin, then to security, config, then update.
