ArcGIS Server 10.2 Cluster Installation
3326
05-12-2014 06:28 AM
ICAICA
Hi guys,
I am trying install an ArcGIS Server 10.2 in cluster mode.
For that, in the installation wizard I use domain account (domain\user), but I received the message: 80070035 - The network path cannot be found
This domain account works fine, I can login in the machine, and I can access shared resources, only the ArcGIS Server Installation wizard fail.
I installed ArcGIS Server clusters in others domains, and no problems.
Any idea?
Thank you.
Regards
BubbaHey
Not sure on this one, but see:
The ArcGIS Server account
http://resources.arcgis.com/en/help/main/10.2/index.html#//0154000004w1000000
PeterPalacios
soporte,
Did you find a solution? I'm encountering the same error/issue with the installation wizard.
-Peter
