ArcGIS for Server with SQL Server DB without the "special" esri geodatabase tables
6567
10
08-25-2014 06:04 AM
Kawaal_Saleem
I've been looking for a solution to have my existing SQL Server database which contains some tables with columns of the data type geometry published as a feature service by ArcGIS for Server without converting the database to a "special" ESRI Geo database by adding other tables.
After long times of searching and trying and failing I've given up.
What I'm trying to do is to show and edit the data using an HTML5 arcgis web map application.
Is it possible to accomplish what I'm trying to do here?
If so, could you please provide me a step-by-step tutorial on how to set up and have it working?
Thanks in advance!
-Kawa
Kawaal_Saleem
I'm using 10.2.2
