ArcGIS Enterprise 11.3, mapping multiple "geometry"
492
09-09-2025 01:03 PM
JeffSilberberg
I have a feature layer hosted that was created in geoEvent.  In the FL is a point geometry field tagged as geometry and radius geometry field to show a ring around the point based on a value (in miles) that is in the transaction being processed.
The geoEvent RTA is working and the Sampler data makes sense, but now I need to show both the Point and the Ring around it on the Map, but while I can open the FL in Map Viewer and create the Map, I can not get the Rings to populate on the map and while this map is fairly straight forward with a single ring, the next one map have up to five (5) rings around the point.
Any guidance would be appreciated.
