ArcGIS Datastore, Different Data Disk (directory)
1705
02-08-2023 01:07 PM
danbecker
ArcGIS Datastore (Windows) is installed in C:\program files\arcgis\datastore
When I use this command to create the datastore, the data directory defaults to c:\arcgisdatastore.
configuredatastore.bat azarcgissvr01.ad.domain.com server_admin password123 E:\arcgisdatastore\ --stores relational
I figured I could create a Premium SSD disk (Azure) then have datastore read/write to that directory.
So, I uninstalled DataStore and instead installed it in E:\. After this, when datastore was created, I was able to set as E:\arcgisdatastore. But....now none of the cmd line utilities work when accessed from E:\....tools\. Error: the system cannot find the path specified.
Is this expected behavior?
B
Scott_Tansley
MVP Regular Contributor
No.  I always install program and data/config files on a D or E drive.  I use the command line tools a lot and I have never observed that behaviour.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
danbecker
Maybe this issue is related? My install path was E:\Program Files\ArcGIS\DataStore
..with a space
https://support.esri.com/en/technical-article/000015832
Scott_Tansley
when you run the command wrap it in double quotes, that way the space is respected.  When I install to a secondary drive, I ignore the "program files", so I install to D:\arcgis or E:\arcgis .  ArcGIS is the only app installed over the top of the OS, so it's a bit redundant in my case.
try the double quotes - or use CD to navigate to the folder in command prompt and then run the tool from within the folder.
Scott Tansley
danbecker
This problem was fixed by simply rebooting the VM, all is well now, Lol.
I uninstalled datastore from C:\, then reinstalled on E:\ without rebooting in between.
