ArcGIS DataStore 11.4 - Replace SSL Certificate for Relational and Object Stores
1998
02-21-2025 06:33 AM
DavidColey
MVP Frequent Contributor
Hello - following the guidance here for using the updated replace ssl certificate utility command (as opposed to the deprecated update ssl certificate utility command):
https://enterprise.arcgis.com/en/portal/latest/administer/windows/update-ads-ssl-certificate.htm
My relational and object stores are on different machines.
On the Object Store, I think I want to specify the utility with the "-- relational" option, thereby ensuring the Object Store can communicate with the webserver and the Relational DataStore.
On the Relational Store, I think I want to do the opposite: Specify the utility with the "--object" option, thereby ensuring the Relational Store can communicate with both the webserver and the Object DataStore.
Can anyone confirm?
David
DavidColey
Support agrees the help is ambiguous.  With my current distributed deployment setup, I will want to specify the "-- web server" option on both of my datastores, since I have a single relational datastore and a single object datastore server communicating with my Enterprise ArcGIS Server host site through the web adaptor.
As far as we could tell, you would maybe specify the " -- relational" option on a relational datastore in an HA deployment so that the primary relational datastore could communicate with the standby datastore.  Or maybe if the relational datastore were communicating in some other way, not through web adaptor.
The same would apply to the object store :  If object store is communicating with other object stores in a 3 (or more machine) cluster type, or if the object store needs to communicate with ArcGIS Server through another type of load balancer.  Or proxy.... But I don't really know because were not set up that way.
Esri Case #03842891
