ArcGIS and Nutanix?
7555
13
03-04-2014 06:54 AM
DEWright_CA
Has anyone else started looking or is working with the NUTANIX platform for VMWare and powering ArcGIS Services? I am intrigued by the mix of SSD to store the live access data while the HDD array maintains the less accessed data.
Are there any success stories out there?
Thanks;
David
SeanMcLaughlin3
Hi David,
I have interesting updates for you per your ask. Please contact me on [email protected] or 703-980-3291
DEWright_CA
Hi Sean, I tried to email you and the message was bounced as unknown/undeliverable.
Kelly_Estes
Hi David, please try [email protected] that one should work. You can also email [email protected]
RyanDanzey
Esri Performance Engineering is working with Nutanix and will be publishing a blog and content in the near future.
DEWright_CA
Very happy to hear this; it has been years since I broached this topic at #ESRIUC and got blank stares...
DanielThomas1
Ryan,
Has there been any movement with Nutanix and ArcGIS Enterprise?  I am interested in deployment of datastores for enterprise into the Nutanix environment.
DEWright_CA
Hi Daniel, from my view we never saw enough traction from ESRI on this. But I did just complete my second deployment of a full NUTANIX environment for my Server environment and am happy to talk about it. We did not go with the Desktop Virtualization route, we are purely on the converged Server/Storage path.
Running VMWare/VSphere and Windows 2016/2019 VMs.
DanielThomas1
David,
Thank you for your response.  Did you deploy the datastores using AFS as 'OS' less file shares? Nutanix on the surface seems like a good fit for a highly available disk area and would be maintenance free if you go with Acropolis instead of using a Windows OS.
DEWright_CA
Sadly no, because of Auditing and Access-Control requirements we have to go with OS hosted shares for most items. Proper mapping of machines and distribution across your nodes helps a lot with reducing risk of contention and the needs to potentially have machines switch nodes. I went from a 3-node cluster to a 5-node, with one dedicated for cluster-class work.
The mixture of SSD and HDD has been a great performance boost; and maxing out your nodes with the most RAM you can is a huge boost for DB machines.
