Add xsl to xml file
3486
07-08-2015 11:26 AM
RyanSmith1
Hi guys, i have an xml file of which i need to add an xsl to it so that it can be readable on the browser. I tried using the xslt transformation tool and the USGS MP Metadata Translator tool but both didn't work. Am i missing something or is there another way to achieve this?
Regards,
Ryan
JeffJacobson
Do you know what type of metadata is in the XML? If it is FGDC CDSGM, you can use the FGDC Plus Metadata Stylesheet.
The example on this page shows how to link the XSLT from the XML document, so when the user opens the XML, it appears to them as an HTML document.
