Add Graphics to Web Map Task Template
1023
06-24-2014 08:46 AM
WesAskew
When creating print templates to be used in the Export Web Map geoprocessing tool, is it possible to include graphics in the templates? I need to have an organization logo display and it does not show up when access from a REST service and printed from a Javascript application. I have tried to include it in my .mxd templates, but all that appears is blank space where the positioned. Any help is greatly appreciated.
TanuHoque
yes, you can add your logo.
when you add an image into your template mxd, it gets added by reference using the path. In your case, the reason it is not drawing is most likely because the ArcGIS Server account does not have access to that folder.
this is what we usually recommend. After adding an image on the layer, open the Properties of the image, switch to 'Picture' tab and check 'Save Image as a Part of Document' option.
this should do it for you.
