10.2.2 Server and Active Directory Security on ONE Service
2185
05-13-2014 06:32 AM
AlexisGieseker
We have two AGS clustered in an enterprise environment.
Here is what we need to do:
Turn active directory authentication on ONE service. We still need the other services to be able to be open to the public.
Set up:
We have a secure service in arcgis.com with a generic user name and password. We are needing to switch that user name and password to AD authentication. We however don't want to switch our whole server environment to AD.
Any suggestions?
DavidColey
MVP Frequent Contributor
Yes I do have suggestion.  First, you can't run server in mixed security mode.  You must use either AD or use the built-in security store.  I would use the built-in store after setting up your roles and users as most IT departments are quite restrictive. Remember, serverwill inheriet whatever AD policies are in place.  Place the user in the role, and secure the service.  The user will then recieve a log-in prompt through whatever api you are using to display the service.
David
