Feature request: Scope administrative privileges to specific groups
We would like to see more granular control of administrative privileges in ArcGIS Enterprise custom roles. At AFRY, we use a custom role called GIS Coordinator for users who are responsible for GIS within individual projects. These users sometimes need elevated privileges, such as changing item ownership or managing…
Portal token validation failure
Hello everyone! I was digging through my Portal and Server logs while troubleshooting some stuff. Happened to run across a ton of these errors that state Portal token validation failure was classified as an invalid token response. I have been unable to track anything down. See below for detailed log info. I found this bug,…
ArcGIS Portal 10.8.1 createadmin failure.
"I performed a fresh installation of ArcGIS Portal 10.8.1 on a brand-new Windows Server 2019 Datacenter x64 operating system.After the installation was complete, I navigated to createadmin.html to create the initial administrator account. After entering the username, password, and authorization file, I clicked 'Create'.…
"An error has occurred. Please try again later." when accessing settings for Snowflake referenced feature services after upgrading 11.5 to 12.0
We're seeing this error message every time we go to Settings for referenced feature services published from Snowflake, both before and after upgrading from 11.5 to 12.0. This persists after clearing all time history (cache, cookies, etc). Has anyone seen this? What's causing this and how can we fix it? Our datastores…
How can i fix missing postgres binary error while upgrading Portal for ArcGIS from 11.3.0 to 12.1?
I have a relatively small Portal instance on a linux vm running RHEL8. Just a Portal and a federated ArcGIS Server with some map and feature services, all data is stored in an EGDB. When upgrade from 11.3 to 12.1, the Setup on the command line was successful. When I want to finish the upgrade in the browser…
How Can I Improve Portal Search Results for Web Maps?
Hi everyone, I’m managing several web maps and applications in ArcGIS Enterprise Portal, and users sometimes have difficulty finding the correct item through search. Is there a recommended way to improve search results and make important maps easier to find? For example, should I focus more on item titles, tags,…
The portal is not ready connection to the indexer service failed
Sometimes it can happen that Portal gets into an invalid state. "portal is not ready" will be shown in the portal admin in multiple places and "connection to the indexer service failed", as well as index mismatches. However, reindexing or re-configuring is not working to resolve the issue. In HA deployments, unregistering…
"An error has occurred. Please try again later." when trying to view content in the Portal.
Last night, I upgraded our Enterprise instance from 11.5 to 12.1. After the upgrade, everything worked properly. However, this morning, I am having an issue when I try to access the Portal. When I access the content tab in Portal, I get a message "An error has occurred. Please try again later." The issue also only seems to…
Need help upgrading to Portal 11.3 from 10.9.1
I AM GETTING ERRORS WHEN UPRADING FROM 10.9.1 TO 11.3 Portal. I cannot access the data stores. ESRI helped with the upgrade, but they are also without words and can provide no answers. I returned to the backup. Has anyone had this problem and how did you resolve it?
Customize error page when ID is wrong
So, we are moving servers, and links like https://map.devon.gov.uk/portal/apps/webappviewer/index.html?id=aardvarksAreStrange Will not work, as the ID has changed. We will get Is there any way to redirect these to a simple page where we can list the new links? Cheers ACM
Features generalized too much in Map Viewer
I have a polygon feature service that represents a network of utility easements. Individual features are divided by each parcel the corridor crosses. Features are 100' wide and range from dozens to thousands of feet long. In Map Viewer, this layer draws correctly at zoom levels 12 and above. At smaller zoom levels/scales,…
Layer Missing From Recently Overwritten LRS Service in Portal
Recently I have overwritten an LRS service from ArcGIS pro into portal. After it ran, I received the green completion message. When I looked at the service in Portal, the new layer I added to the service appears in the REST API for that feature service as well as the map image layer of the service. However the layer does…
Renaming WMS layers at the point of adding them
OK - I know we are cutting it close, but we are just about to retire our 10.8 server and move to 11.5, but I think this change was made in the 10.8>10.9 jump. In 10,8 when you added a WMS you could rename the layers In 10.9 and above you don't get that. Is this behaviour as designed or am I missing something here? Cheers…
Pop-up only showing title for some users
I was working with a user to help them navigate an app in Web App Builder. I noticed when they clicked features that the pop-up shows only the title bar, with all the other fields/attachments missing. It doesn't do this for me, and I've never seen this issue before. User's pop-ups: My pop-ups: User did say they were using…
Portal for ArcGIS 11.5 Security 2026 Update 2 Patch regression issue?
I am starting to wonder if Portal for ArcGIS 11.5 Security 2026 Update 2 Patch has reintroduced the problem that Portal for ArcGIS 11.5 Security 2026 Update 1 created. I installed Windows Updates last night and when the server came back up the Portal for ArcGIS service refused to start. Finding the log files for that…
Portal auto-adds machine name / FQDN to a custom OAuth2 app's redirect URIs weeks after registration
**Environment** - ArcGIS Enterprise (Portal) version:11.X - Single machine / HA: Single - Web Adaptor: yes I registered a custom OAuth2 application programmatically (ArcGIS API for Python `registerApp`). The redirect URIs are supplied from a config file, and that config does NOT contain the portal machine name or the…
Offline Map Area Not Generating
I am trying to create offline map areas in Field Map Designer. I have received zero issues with this map so far in the process of configuring this map for offline use, but when generating a map area, i get an error message stating "Error accessing item ITEM ID" At first, I couldn't search the ID number, but was able to…
Issues when upgrading Portal from 11.5 to 12.1 - 'Failed to configure languages content during an upgrade'
When upgrading Portal from 11.5 to 12.1 the upgrade fails. In the logs I can see the message 'Reindexing operation failed for languages ' The upgrade continues and in the penultimate entry in the log says that the upgrade has completed. However from the Portal Administrator Directory in the browser it is evident that the…
Why Must Survey 123 Folders Change When Changing Owner?
Hello, I have one other full-time GIS worker on my team, and we have a few Surveys published from Survey123 Connect. Originally I did the publishing on them, so they're under my ownership in the default folder name that matches the survey. When my coworker wants to edit a survey, they change the ownership of the survey…
Upload stylx file as web style to portal, but web style missing for polygons
I've uploaded a stylx file as a web style to portal (enterprise 11.3) from ArcGIS Pro. The stylx file contains 1 point symbol and several polygon symbols (and some color ramps which I understand do not get carried over, thats fine). It uploads just fine to the portal and I can successfully apply the 1 point symbol to point…
Outline Mask Point Feature from Lines
I have a pipe feature class and a manhole feature class, the pipes and manholes are interconnected. I added both to a map. But users reported that they are difficult to identify the manholes from the pipes. Are there any ways to outline mask or isolate the manholes from the pipes on the map viewer?
Why Still Require a Security Question After Installing the ArcGIS Security 2026 Patch 2?
The release of the Portal for ArcGIS Security 2026 Update 2 Patch removes the ability for end users to reset passwords using a security question for built-in Portal accounts, which essentially makes security questions meaningless. Since security questions are meaningless now, why does Portal still require us to specify a…
When upgrading from 11.5 to 12.1 the upgrade installation gets stuck and has remained at the status of 'Configuring the service'
I know that other users have experienced a similar issue documented here https://community.esri.com/t5/arcgis-enterprise-portal-questions/portal-for-arcgis-upgrade-from-11-5-to-12-1-not/m-p/1704601#M17369 I had already applied the patch which was meant to have fixed this problem - Portal for ArcGIS 11.5 Security 2026…
Utility Network Sewer Main Lines: Labeling Issue
Hello, I have created a custom Label Expression for our wastewater main lines, lateral lines, and manhole assets. The custom labeling is requested from our Sewer Collections crew. This is the labeling standard that we want and are achieving in Pro and in a Map Image service: But this is what we are getting when putting…
How can I change the Portal Navigation Bar?
Hi all, I would like to change the links displayed in the Portal Navigation Bar. Is this possible? And if so, how can this be done. I am the Portal Admin. Thanks! Shane
