WMS service connection error in ArcGIS Portal 10.9
1104
11-23-2023 02:54 PM
NesmieianovViktor
ArcGIS Portal runs in a enterprise environment.
Web Adapter is installed on a separate Linux container.
version 10.9
In a corporate environment, there is an additional proprietary WMS service.
If I request
https://myserver.corporateserver/wms?service=wms&request=GetCapabilities
on the browser page, I get the correct response in xml format
When I try to add a service as an Url From Internet WMS(OGC) element, I see in the console that a request is being sent
https://myarcgisportal.corporateserver/arcgis/sharing/proxy?https://corporateserver/wms?
and this request returns error 500..
What needs to be configured to be able to add WMS services to ArcGIS Portal?
NesmieianovViktor
The problem was solved by installing the additional organization certificate
arcgiswebadaptor/arcgis/portaladmin/security/sslCertificates
A_Wyn_Jones
Hi @NesmieianovViktor,
Could you please ask your Portal admin to check whether the Proxy hosts have been restricted?
https://enterprise.arcgis.com/en/portal/10.9.1/administer/windows/restricting-the-portal-s-proxy-cap...
The machine where ArcGIS Portal is running may not have a connection to your WMS endpoint - this can be checked by using the checkURL function of Portal.
The URL may need to be added to the allowedProxy list or you may find there are some connectivity issues to the URL.
Hope this helps,
A
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
NesmieianovViktor
Hal-AhmedShehata
I'm trying to use ArcGIS Online with WMS and having the same error. Obviously, I can't import certificates in AGOL. Any idea what can be done?
