Which token types should be requested from OIDC Identity Provider?
516
01-16-2026 07:16 AM
GSpeed_UU
My identity provider is asking which tokens I need to authorize for setting up an Open ID Connect single sign on.
The options are:
  • code
  • id_token
  • access_token
  • refresh_token
Which ones are required for ArcGIS Enterprise Portal 11.5?
Tags (4)
JeffSmith
In most cases returning the id_token is sufficient.  This assumes the id_token includes the user profile information like name and email address.  If this information is not present in the id_token, Portal for ArcGIS will try to access the user profile url to retrieve this and usually requires an access_token for that.
JeffSmith
