Web Elevation Layer showing as Imagery Layer in Portal even though shared as Web Elevation Layer
1543
10-21-2020 11:24 PM
by Anonymous User
Not applicable
Hi all,
I'm getting some strange behaviour with a Web Elevation Layer I am trying to publish to Enterprise Portal.
In Pro the Elevation Layer is referencing a Raster dataset that is sitting in a registered EGDB. This raster dataset has been published as other services in prtal such as an Imagery Service.
For some reason when I go to publish this as a Web Elevation Layer. Everything is correct (it even shows in Pro that it will be published as a Web Elevation Layer, correct icon etc). It ends up showing up in Portal as an Imagery Layer...
The issue with this is that I cannot add it to the ground/surface in the scene viewer.
Has anyone else experienced this and have any ideas as to why it won't publish as a Web Elevation Layer?
Also no errors or issues during the publishing process.
Cheers,
Cam
by Anonymous User
Not applicable
Of note this seems to have been once off behaviour and restart of ArcGIS Pro / Machine fixed the issue.
by Anonymous User
Not applicable
