VB or Python script for County label that drops the last word in a field
11873
14
05-19-2014 02:14 PM
TiaMorita
I am trying to create labels for a county field name (called "Name") where I drop the last word "county". For example, the Name field has "Los Angeles County" and "Santa Barbara County" and "Ventura County" - but I just want these labels in my map to read: Los Angeles, Santa Barbara, and Ventura. Is there a way to delete the last characters or just drop the whole word County in a script?
Thanks!
JoshuaChisholm
Hello Tia,
My apologies, .rstrip() isn't exactly what I thought it was. You should probably use Greg's .replace() method.
Good luck!
TiaMorita
Ok. This works on your sample data.
In Field Calculator...
1. Change parser to python
2. Check Show codeblock
3. Paste the code below into Pre-logic script code
4. in the name = box, enter losemunitype(!name!)
def losemunitype( name):
    lsttypes = ['County', 'Parish', 'Borough', 'Municipality', 'Census Area', 'City and Borough']
    for losetype in lsttypes:
        if losetype in name:
            return name.replace(losetype, '')
    return name
AWESOME! Works like a dream! Thanks!!
RaymondHuang
Hi Tia,
Great!! I think you should help to mark the post by Greg as the answer. 🙂
Raymond
Zeke
Honored Contributor
One caveat to the script: it does what you asked, but if you had any of the words in the list that precede the part you want to retain, it will delete those as well. So 'County of Los Angeles' becomes ' of Los Angeles'. If you want 'County of ' deleted, add that to the list. If you only want 'County' deleted when it's at the end, change this line:
to
if name.endswith(losetype):
JoshuaChisholm
If you only want to remove the suffix strings from the end of the name field, you could modify Greg's script like this:
            return name[:-len(losetype)].strip()
    return name
[INDENT]The .strip() just gets rid of the space left over at the new end of the string.[/INDENT]
PS. I switch the green check to Greg's original response. I hope that's ok!
