Using a buffer to associate multiple features for each feature in a layer
2180
04-28-2014 11:08 AM
AntoineNormandin
Hello,
I am trying to determine for each point in a layer which other points, in the same layer, are located within a certain distance.
I realize this is not particularly clear and have therefore attached an image of what I am trying to achieve.
As illustrated in the example, I have created a buffer around point 4502. Located within this buffer (B) are points 4500 and 4480. Therefore, the points 4500 and 4480 can be associated to 4502.  Pursing with this logic, buffer A was created around point 4500 and overlaps 4498. Consequently, 4498 can be associated to 4500. This operation would have to be repeated for each point.
I then need to obtain an attribute table that would look like this:
Origin___Point 1___Point 2___....
  4502____4500____4480
  4500____4492
Thanks for your help!
JimCousins
How about ArcToolbox >> Analysis Tools>> Overlay >> Spatial Join
choose One to Many as the join operation, and set the search radius as desired. Then you need to create a crosstab to rearrange the data. Do this in excel (easiest as far as I am concerned) or try the Transpose Fields tool.
Best Regards,
Jim
