Updating Maxrecordcount
2623
08-14-2020 01:00 PM
najeebhall
I have been attempting to update the definition of a hosted feature layer using the admin menu update feature definition option but  have not been successful. I have used the update definition many times before for other purposes that work, but when i change the maxrecordcount from 1000 to 2000 I get the message saying it was successful but the count doesn't actually change it is still 1000, should i be doing something else to do this? See images below:
SeyniDjibo
Esri Alum
Hello Najeeb,
What version of ArcGIS Server are you on?
Could you update MaxRecord by editing the hosted service instead?
From ArcGIS Server Administrator Directory > browse to the hosted feature service > edit from the bottom of the page > search for the MaxRecord in the json page and update MaxRecord.
Thank you.
najeebhall
we use version 10.6
Does the picture below capture what you meant?
i made an attempt but getting this error. I wasn't sure if ArcGIS Server Administrator was a completly seperate application
najeebhall
Update,
i went one step back and clicked edit from the main layer page
I attempted this below as well as coping the entire json and just changing that line, both yeild the error seen below
