Remove lateral panel in Web Map Applications
1546
03-15-2023 03:31 AM
LMBaptista
Hi, everybody.
I have several applications that I want to insert in a Map Gallery in a Site.
I created the link as a WebMap Application and then use that URL to add as content. Everything works fine.
However, when i open the app through the Map Gallery, there is a left panel with several metadata that I don't want to show (see image attached).
How can I remove this panel?
Thanks in advance
LMBaptista
Solved.
We must turn off the "embedded applications" under Configurations --> Interactions.
Thanks anyway.
LMBaptista
Solved.
Thanks anyway.
