Problem with Project Tool
1285
03-10-2013 08:20 AM
ThomasHohne
I am trying to project some point data, which is in a GCS decimal degrees format. I have used the Feature Class to Coverage (Conversion) tool to create a Coverage. Then I'm trying to use the Project Tool to project the coverage, using the following projection file:
input
projection geographic
units dd
datum nad83
parameters
output
projection utm
units meter
zone 11
datum nad83
parameters
end
The problem is that, well, nothing happens. The tool seems to execute fine, but no output coverage is created.
I'm sure I'm missing something obvious here, so any help would be appreciated.
Thank you,
Thomas
WaelYahya
Please send me a sample data on my email @ [[email protected]]
MelitaKennedy
Esri Notable Contributor
Hi Thomas,
i don't see anything wrong with the projection file. Can you reproject the coverage data on-the-fly in ArcMap? If nothing shows there, check the input lat/lon values. Do they overlay properly with your other data? Longitude values are negative? Latitude = y, longitude = x?
Melita
