Portal index shows less groups and items after upgrade from 10.9 to 11.1
547
03-18-2024 10:11 AM
Labels (2)
Thomas_Puthusserry
Just completed a HA enterprise upgrade (2 portals, hosting server, fileshare, 2 relational datastores and 2 tilecache datastore). It all looks fine, however the portal contents as seen in the index status is a bit puzzling.
After upgrade the groups and search (items) has come down. Is this normal?
TimoT
Don't think this is normal.
If you check the index status on each Portal machine via port 7443 URL, do both machines report identical index status?
Timo
Thomas_Puthusserry
Hi @TimoT I checked both portals separately via 7443 and the numbers are same:
Not sure why this is now accepted as a solution 🙂
