Polygons sharing boundaries
3970
09-24-2012 05:20 AM
LarsAnker-Rasch
This is the idea: Lets say I have two polygons laying next to each other. If i start zooming in on the boundary, a small gap will appear between them. I want the two polygon boundaries to merge into one single boundary. As a result, when I start to correct the boundary (by dragging the boundary to the left) the feature of the polygon on the right will fill up the new space, i.e; not create an open space between the two polygons.
I've looked at some other threads on the forum and found one that uses Integrate (ArcToolbox -> Data management Tools), but It didn't really do what i wanted it to.
Any help is appreciated.
ArcMap 10.0
AlexeyTereshenkov
MarkBoucher
Honored Contributor
Learn and use topology rules/tools.
http://resources.arcgis.com/en/help/main/10.1/index.html#/An_overview_of_topology_in_ArcGIS/00620000...
hese are related to the align tools Alexey points out and they are available in 10.0.
LarsAnker-Rasch
Thank you. But I immediately get problems using that solution. I right-click on my feature dataset to create a Topology, but there is no "New->Topology" when I right-click.
Could this be because I don't have the proper license?
MarcinGasior
...there is no "New->Topology" when I right-click.
Yes, Geodatabase topology requires at leas ArcEditor (Standard) license.
But instead of geodatabase topology you can create temporary map topology in edit session.
Look at this ArcGIS tutorial exercise for example: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001t00000021000000.htm
