Map Viewer Filter missing 'in the last'
1249
12-06-2023 11:12 AM
SpatialSean
Running Enterprise 11.1
My date field last_edited_date for one layer is not allowing to filter 'in the last'.  This is for all of my feature classes created in Pro on a SQL database and are hosted feature layers.
I looked at a feature layer created from S123 and that layer has the option so I am trying to figure out if there is a specific setting to allow this?
lah
I'm also missing the "in the last" filter option with all of my DateTime fields in a SQL SDE on Enterprise 11.3. Did you ever find a solution to this?
SpatialSean
I created a workaround using an Arcade script for the symbology.
Pending update to 11.4 where hopefully it has been added.
lah
Very strange considering this has supposedly been supported since 10.9.1: https://enterprise.arcgis.com/en/portal/10.9.1/use/apply-filters-mv.htm#ESRI_SECTION1_41D232C2335C4B...
