Map Image Layer and Feature Layer publishing with different field content?
582
07-30-2024 05:08 PM
Labels (2)
amarcz_cc
Using ArcPro 3.3 to publish to Portal (11.2)
I am publishing a layer out of my Enterprise GDB to make a dashboard, but I am getting error in the Feature Layer data contents.
The Feature Layer is publishing the same content as a different field within the feature class for some reason.
Deleting the service (Map/Feature layer) & republishing do not correct the issue.
Example below:
Source SDE GPP Field Published Map Image Layer GPP FieldPublished Feature Layer GPP Field
RLRL(RL) Low Density Residential (2-4.5 du/ac)
The Published Feature Layer appears to be copying the data from the field GPP_DESC into the field GPP, but still keeping the GPP_DESC as the longer example above.
Anyone else experience this?
