Linking to external documents in a Web App
1520
09-28-2020 09:47 AM
MonicaBeaton
I am creating a Web App in Portal (10.7.1) using a Web Map that contains multiple map services. One example of the linked documents I need the users to be able to retrieve is a Survey Plan. The map service has a "Survey Plan" polygon feature layer with a pop up that will return the Survey Plan Number and I wish to have a link to each plan's actual PDF document that will open up in the Web App.  The survey plans are currently stored on a Sharepoint site but could easily be move to a internal network folder location if that works better.
Do I have to register the Sharepoint site with the Data Store or add another column to the survey plan feature class/layer with the URL? Is there even a way to do this?
Many thanks for any help!
Tags (1)
MonicaBeaton
I figured this out. I guess I posted my question too soon; a little sheepish to admit that I forgot to add the HTML Popup settings before publishing the map service to Portal! Ah well, live and learn.
